sdn25
- Joined
- Apr 24, 2022
- Messages
- 260
- Reaction score
- 159
SOLUTION: I blew my OT due to having my bias set at 70mA as a result of a measurement error, had to get that replaced.
So basically, I had built a plexi 50 lead kit from Ceriatone, a 68' circuit that is for the exception being that I have the 47k NFB going off the 4ohm tap. I was recently playing the amp and all of a sudden the volume just tanked. I looked over and the tubes were red plating. I immediately put it on standby and decided to check the bias once the tubes cooled down a bit. I always run the amp between 7 and 10 on the volume, so full blast.
It has only been 3 days since the amp was built, I had a pair of brand new JJ EL34s installed from TAD.
I used a multimeter to check idle bias. At idle the amp did 33mA from the bias probes on the back of the amp. But at idle the pins on the tube sockets read 55mV, which is too high right?
So, I lowered the bias using the bias pot to where it read 35mV on the pins at idle, but it then read 18mA at the bias probe points on the back of the amp.
The tubes were ONLY redplating when a signal was passed through. I’m aware the plates inside the tube started to glow red and not the gas glow. All tests were done with a load.
While checking the amp with the lights off and I passed a signal through again, the tubes made a crackling sound and they just died. I should mention that throughout all this the volume output from the amp was severely diminished as that’s why I checked it in the first place.
The tubes redplated even when the volume was very low.
Now, I checked all the pins on the socket and compared it to the voltage chart that Ceriatone have on their website for the plexi 50 and they were within spec. This was tested before the tubes died. Could this still suggest that I have wired something wrong?
I then decided to test the amp again once more after the tubes died so I pulled the power tubes and tried to test since I've read these amps can be tested without power tubes, I still had a load connected. When I powered it on the HT fuse blew.
I was hoping if any amp wizards here have any suggestions as to what may cause this. Thanks in advance!
SIDENOTE: I use a Suhr reactive load as my load. Impedance selector at 8ohm setting.
Here is the layout of the amp from their website.
