Pete Farrington
What do you mean by ‘earlier’?Would the 470k mixers cause the amp to start breaking up earlier?
I normally turn it up to 6 for the grind I like. Would that grind start at 4 with 470k mixers?What do you mean by ‘earlier’?
The degree of any change will be affected by the relative channel volume settings, but even at the most it won’t be that much.I normally turn it up to 6 for the grind I like. Would that grind start at 4 with 470k mixers?
I figured that was probably the case.The degree of any change will be affected by the relative channel volume settings, but I don’t even at the most it will be that much.
Overdrive will still happen at the same power output and SPL levels.
Didn’t Marshall make a Bluesbreaker once upon a time 😉
