This is my first Ceriatone kit, we’ll see how it turns out. It’s a little more challenging than my Valvestorm kit but it is coming along.Looks good. Never done a ceriatone. I did order a JTM black flag panel from Nik...never used it. :facepalm
I've pondered a spitfire or lightning many times.
The 100 watt 2203 definitely sounds different than the 50 watt 2204 and it’s not that much louder. There, now go build one.Yeah mine are all based on the metroamp instructions. (2) came from metro as kits and the other I did from valvestorm and sourced some stuff, etc.
Those are a ball.
I'm fighting the urge to do a 100 watt head. cuz..WTF am I going to do with a 100 watt?
And 3 50's are redundant as it is.
It was a little harder than with a 2204 style chassis. But it was easier than I thought it was going to be.It looks hard to get to the pots with that chassis, You seemed to do a good job though
Just re-read this. Would the 470k mixers cause the amp to start breaking up earlier? I’m thinking that might allow me to turn the volume down a bit.Looks good to me.
That wire between pi and treble is normal on 4-holers without MV or loop.
Consider 470k mixers where the two channel volume wipers merge (vs 270k). It gives more grit and grind.
