The chassis has been bolted in to the new cabinet
Whats the story on the cabinet? looks nice.
How many kits have you built?One month later and everything arrived today. The transformers were already bolted in and all the components were neatly packaged in the chassis.
Uhhhh, 9 I think. This will be my third Marshall clone.How many kits have you built?
The cabinet was built by Sourmash. They look better to me than the Ceriatone cabs. They will make it to any dimensions you want as the opening needed to be wider and it needed to be deeper to accommodate that chassis. They even pre-drill the holes for the logo. They will not drill the holes for the chassis however.
I got the logo from Amplified Parts, the 6 inch one. I use a rubber mallet to tap it into place, no glue needed.Chris I'm going with the same cabinet for a project. I think I will give sourmash a try this time. I assume they didn't sell the logo? I'll have the holes drilled but wondering where you got the logo?
I used my meter to check for continuity and shorts after I got all of the heater wiring in place. It looks good so far.Looks good you can test for shorts with a meg meter
Noted.Recommend a far more robust steel screw, lock nut, and star washer for your AC mains to chassis ground.
Yes, that’s what I thought. The wires they sent with the kit did not match the wire colors on their layout, and no yellow. Oh well, one of my kits came with practically all white wires. It all works so no problem.Nice but interesting wire colour scheme for a 'Marshall'!![]()
