Can new electrolytic caps make an amp sound punchier?
EADGBE
My TSL's caps are twenty years old. There's no hum or anything yet though.
Jon Snell
Jurassic Coast, England
Depending on where it is, if the old capacitor has dried out and not up to value, replacing it will restore the punch to the power supply by returning the "tank" that holds the energy back to the correct value.
william vogel
If the amp has no conditions of degraded capacitors, it’s hard to say for sure if replacement will give you any benefit. Different brand capacitors will give different results. I use F&T capacitors for most of my amps. I use Sprague Atom for Fender usually and Trainwreck stuff exclusively. Nichicon also makes good capacitors.
neikeel
As above
If they are failing yes you might get an improvement but if they test up to spec and are not humming etc probably not.
Generally you find that new high quality output tubes correctly biased are a more likely method of restoring punch.
wakjob
C-137
You could look at it as cheap insurance, and a big reassurance.
Normal maintenance IMO.
