Buzz on 8080 valvestate
spebblechunky
Hi all - I'm getting this buzz that sounds like a ground loop on this amp. It is audible with everything turned to zero, goes up a bit with the master up, and then goes up a lot with increase of volume.
I replaced the filter caps and tried re-flowing the solder on the output resistors and a lot of other places, looking for cracked leads. Cleaned the hell out of the pots. Tried another tube. It's still there when I disconnect the reverb.
I don't have a scope but I have a signal tracer so I can listen to the signal path to try to figure out where it starts. Could anyone recommend where to look for that ground loop, given what I have mentioned so far?
Tatzmann
All the 8100 have this as far as i know. 8080 is the same amp.
Cant remember if i ever read about a solution of this and it never bothered me too much that i had to investigate it myself.
It may had something to do with a cap in the powersupply, but since they are changed already, idk.
Its a fairly known quirk of those amps, some extensive googling could bring up an answer.
spebblechunky
Check the input socket. Probably a broken ground link or a faulty socket.
Thanks Jon. I checked the jack and it seems okay. Actually the buzz is there at a low level even if I plug a cord into the effects return with everything zero'ed out. Any other leads?
Jon Snell
Jurassic Coast, England
What happens with VR13 at zero. If there is still hum, what frequency is it? Mains or twice mains?
If R13, master vol, is at zero, that removes the preamp/reverb recovery from the equasion ... assuming the ground is good on VR13 pot!
Have you checked the reverb?
spebblechunky
Okay with vr13 (master) at zero, the same hum is there at a low volume. Turning up gain and volume brings it up much higher. I guess it's a mains frequency 60hz, but clipped like in this screenshot, which is maybe why I thought it was 120hz ground loop. Seems like ground is good on vr13.
Unplugging the reverb tank doesn't change the buzz.
spebblechunky
Actually, with a signal tracer, I cannot hear the buzz on IC1, IC2, IC3, but then I can hear it on the input of IC4, so it seems it is somewhere around there. When I wave the signal tracer through there not touching anything, I can hear it picked up from the auto transformer pictured here. So I guess that is the source.. I don't know if something is grounded wrong, or that xformer would need to be replaced.. Still poking around.
Jon Snell
Tat means the hum is coming from the valve pre amp stage.
I would firstly check the valve, then look for ripple on C53 and C59.
Think back a few suggestions ... the grid of V1 connectes to ground at the input socket! Have you replaced the socket and checked the soldering?
