Marcus Johns
- Joined
- Sep 3, 2021
- Messages
- 58
- Reaction score
- 25
@neikeel thanks mate, I do agree I’d rather build the 2 in 1 straight up, I guess if I need to do any troubleshooting I can always get some voltage profiles from here or Metroamp forum?
Just confirming, with the 2 in 1, in 2204 mode (pot pulled out) the inputs are 2204 low and 2204 high, and in 1987 mode (pot in) you get 1987 bright low and 1987 high? You also mentioned the master vol works well in 1987 mode as well? So no real need for a PPIMV? I’m also looking to put in the Metroamp zero loss effects loop, it’ll be easer to drill the two holes for this prior to starting the build (along with the holes for the two switches for NFB and bright cap).
I’m starting to get a parts list together, someone already mentioned the 2 x F&T 50/50uf filter cap cans that I already have will be ok to use. Only other questions are:
- Synergy royal mustards vs Sozo Next gen coupling caps?
- Sozo silver mica 1000v vs other silver micas?
- NOS CC resistors as per the Valvestorm Diagram vs all Carbon film resistors?
cheers
cheers
