Hi,
My JVM410H started making some strange noises. I thought it was a bad cable but it was not.
After checking it out, one of the EL34 was the culprit. Nothing strange so far.
Then I went to replace the tubes and check BIAS. Thats when it happened, one side the bias was around 20V (yes volts, not millivolts), the other around 40mV. Half of the tubes were too hot, much hotter than the other half.
After some digging I found that R27 (1R, 1W) was blown and that was driving the BIAS problem. I replaced it with a new one (10W this time) and proceeded to set the bias.
Everything is OK now.
I'm posting this to find if someone has already bumped to this issue.
I also plan to replace also R26 to a 5 or 10W resistor because it has the same function of R27 on the other half of the power amp.
