Red Solo Cup
Like the sound? Inspires you? Run it until the house catches fire. It's only rock-n-roll.
Don't overthink it (as I do all too often). Enjoy.
Do they get hot? What Marshall doesn't?
First, JCM 800's are the last good Marshall amps, as far as heat is concerned, according to my amp tech.
……. I brought a jtm60, …. I have had it looked at by Marshall, ….. since buying it I've only heard bad things,.. ….. now considering it's around 25 years old it looks in pretty good shape….. have I made a boo boo?
I have a JTM60 2x12 combo too, in fact I am the original owner.I don't know anything about amps and without seeking advice I brought a jtm60, I have had it looked at by Marshall, since buying it I've only heard bad things, now considering it's around 25 years old it looks in pretty good shape, ie non of the yellowing or other signs of overheating, it does "buzz" but the buzzing seems to quieten down when I touch my guitar (strings, bridge etc) apart from that it seems to sound great, anyway back to my original point, have I made a boo boo?
Good advice imo,……………..It's only rock-n-roll. Don't overthink it (as I do all too often). Enjoy.
This question reminds me of a chick I asked this of once.
Pretty much.....lolLooked good, got hot, but a bit noisy and the bottom end became flubby after a while?
Pretty much.....lol
It's a transformer that's putting out the heat. Get a small fan and you'll be fine. Doesn't need to be fancy.I don't know anything about amps and without seeking advice I brought a jtm60, I have had it looked at by Marshall, since buying it I've only heard bad things, now considering it's around 25 years old it looks in pretty good shape, ie non of the yellowing or other signs of overheating, it does "buzz" but the buzzing seems to quieten down when I touch my guitar (strings, bridge etc) apart from that it seems to sound great, anyway back to my original point, have I made a boo boo?
The heat is natures way of telling you it’s ain’t digital shit!![]()
Not likely. You're not a good groundFirst,to the forum.
Sounds to me like the buzzing is caused by your guitar not being properly grounded. That's why the buzzing stops when you touch the strings or bridge - you have become the ground.
As for the amp, if you like the way it sounds is all that matters. I would have a fan installed, or at least a fan blowing from behind it to avoid overheating.
Semantics. The symptom still suggests an improperly grounded guitar. Technicaly, the guitar is grounding you.Not likely. You're not a good ground
