Anyone have a 5010 Master Lead 30 (smaller version)?
fitz
Well-Known Yinzer
the Burgh
Looking for some chassis dimensions if possible.
For this one:
Not this one:
fitz
Well-Known Yinzer
the Burgh
Nope!
That one's got reverb!
Yes, but I think that's the same chassis as the smaller 5010.
I'd go for the 5203 also if it was here in the States - and a 120v version.
Odd that they list the width as the same.
The Master Lead Combo looks wider...
My suspicion (and what I've been image searching for) is that it is the same width as a 1912 cab.
That's what I'm hoping for.
My head shell would hold a chassis that size.
The 5002 is swimming in there and I could put in a bigger chassis.
Tatzmann
If my memory isnt deceiving me then the last ones of the Master30 amps were a little different from the earlier ones.
They added red led diode clipping to the circuit and probably changed the preamp circuit accordingly.
fitz
Well-Known Yinzer
the Burgh
Which one's the latest one?
Gunner64
Midwest, USA
I got one. I'll measure when I get home. It's a later one, with the block letters. Made in 1990. See my "so I've been offered a trade" thread.
I like it. It has a presence control, and the controls are pretty much laid out like a 2203/04.
Edit: nevermind, I see you have your answer.
fitz
Well-Known Yinzer
the Burgh
When I measured my 5002 chassis, it was about 17-1/4" (may be a bit less).
Not sure how accurate the Reverb seller was with their 17" measurement on the 5010.
If you can confirm an accurate dimension on the 5010 chassis width, I'd appreciate it. :yesway:
There is plenty of room in my home build head shell for either, but I'm still curious if I can jam the 5002 into that 5010 cab with the 12" speaker - Lead 20 combos are a 10".
Gunner64
Midwest, USA
Yep Fitz, measuring the 5010 I have the chassis is 17 1/4"
