if it's similar to the doubler i posted i would make sure you use equal capacitances (really, the same caps so that things like esr are the same) for the "top" and "bottom". 100nf or so film/ceramic cap in parallel to each branch is a good idea as well
Yes, I plan on keeping the C1 C2 same values. The datasheet for the L7806 regulator shows a .33uF and .1uF non polarized cap on each side of the regulator, so I will do that as well. The parts are now adding up and finding space is going to be tough. But this is a good problem to have.
I went with that doubler I posted, as I did not see your drawing till I already got started. Any difference you can think of between the two?
I had initially kept an inline fuse coming off the high positive side transformer 5V tap leg as I was experimenting. I am low on fuses and was initially blowing the fuses I had in there lol. But that had to be from the inrush/powering down discharge spikes. Last fuse I blew was a 1A slo blo. Then I just removed the fuse. It is just temped in there right now. But I had three 12AX7's heaters and relay coil powered/holding and 13.4VDC into regulator and holding 6.01VDC out of regulator. This was with huge caps temped in there of 6600uF / 13300uF (oddball pairings as I had to jumper in odd values I have on hand) and no small film caps in there yet for parasitics.
So I do not see any reason I can not run two 12AX7's and the relay safely at 6VDC and not have to worry about it. I was wanting an inline fuse in there, but as I said before, the space inside is a problem at this point and that huge inline fuse wire will then be mixed in with other sensitive wires and probably adding noise.
I need to try today, running the two 12AX7/relay on this 6VDC and I need to load all sockets up with the rest of the AC heaters draw AND load in a pair of KT66 and then see if I still have my 6VDC lol. The numbers above were with 6V6 and one 12AX7 6VAC socket empty. My AC heaters were at 6.9VAC lol. So that was not pulling down the PT secondary much at all.
