I knew there was a subconscious reason why I reached for that 10,000uF filter cap when I was not getting my results with the lower capacitance values (besides not having many cap values on hand).
This Granger board is using two 6,800uF caps for its DC filtering. But then, they are using a voltage regulator as well. You can power the three relays or use only one or two relay sections with their power supply, so they advise.
https://grangeramp.com/wp-content/uploads/2020/01/3_relay_board_full_wiring_diagram.pdf
Would you say that is dangerously high filtering for that circuit? I have only a 470uF, and then some 3,300uF. I had a 1,000uF the other night. Have to find what I did with it lol.
