AB763 - Deluxe Reverb Build - Hum at Idle - Solved
ToneWitch
Lake Havasu AZ
Built this deluxe reverb from mojotones spec and layout.
My power and preamp grounds are seperated.
I have a long ground buss wire tucked up above the pots. Using the PT center tap.
I went through the normal check. Pulled one tube at a time. The hum stops when you pull the PI tube. The hum does get louder as you turn the volume up. No other control effects the hum. The hum is there even with no guitar plugged in.
So I checked everything at PI section of the board. It’s all good. Nothing is sensitive and my voltages look fine.
The amp sounds incredible. But this hum is killing me. I am aware that fender used a large brass plate behind the pots. Idk. This has got me stumped.
neikeel
On my build I spent a while checking for ground loops and power supply filtering. I got the scope out and discovered it was inadequate filtering on the bias - hum was coming through the grids!
Would be very interested to know solution here.
ToneWitch
Lake Havasu AZ
The heater center tap? That will cause serious hum. Glad you found it.
Yeah, for some reason I thought this transformer had a low voltage and high voltage center tap. So I had convinced myself it was already in. Then realized the transformer only has a high voltage tap. 2 100ohm resistors off the bulb and it’s so good now.
Im247frogs
Brooklyn, Joey!
I recently bought a Silverface Bassman that some genius had desoldered and taped off the 6v center tap, for some unknown reason. Maybe they did it and then forgot to add a virtual ct? Hummed like a power station. I could see why the recording studio I got it from couldn't use it. Awesome amp, shoulda kept it.
Dblgun
AZ
neikeel, did you increase the bias cap over the 25uf used originally? If so, how much did you have to increase it to eliminate the hum?
