5F6-A 2204 Build
Chris-in-LA
I got the itch reading the recent build threads and I couldn’t resist. I was thinking about building a 4x10 cab but decided to add a little more money and ordered a Bassman kit from Mojotone, speakers from Weber. Since I already have a number of amps without a master volume and really can’t play them much at home, I decided to build this Bassman with a 2204 front end. These amps can be loud so I decided to experiment. The layout of the 5F6A is not that much different from the 2204 and I like the way that the volume controls work on the 2204. I ordered the kit last Monday and already received the parts, the case arrives by Monday.
The only thing I don’t like about Mojotone tweed kits is that you have to figure out where to drill the holes for the circuit boards. Once that was done, I mounted the transformers and tube sockets.
Trouble
USA
Chris-in-LA
Do you guys think it matters? Should I wire the heaters in Fender or Marshall style?
Trouble
USA
I don't think it matters my last couple fender builds I used the Marshall style.
thetragichero
upstate ny
either way can work well when done well. my most recent build is a combo of both since the power tubes and phase inverter are close together while the preamp tube is much farther away from them (pentode preamp). i generally base it on how i see the rest of the amp going together
Chris-in-LA
I'd go Fender style throughout.
Ok, Fender style but it looks like it doesn’t really matter. Did a little work on the power section while waiting for this answer. BTW, what is the purpose of that .047 cap on the standby switch?
adew1
Switzerland
I've got my popcorn ready too. Looking forward to seeing what you come up with!
thetragichero
upstate ny
cap likely prevents arching, although I'm not sure if I've seen on a standby switch (unless it's pre-rectifier). i use on the mains power switch (i usually don't use a standby switch)
unless it's to ground after the rectifier, i have seen that
Chris-in-LA
Yes, it’s to ground after the rectifier.
South Park
It works like a soft start to me the cap charges up first then goes to the power rail . Some old school stuff you still find . So if you build the cascade input are you going to have the all the inputs or just two 6l6 or el34 power
Chris-in-LA
Two inputs wired like a 2204 with Cliff jacks.
Chris-in-LA
Finished wiring the preamp section. I had a bunch of Valvestorm wire leftover from some previous builds and couldn’t resist using it. I also had to drill out the input jack holes to fit the Cliff jacks.
Chris-in-LA
The board is finished, just need to check all the connections after a good nights sleep. Next step is to wire the heaters and put in the pots.
