Asking Price is $1600
Ideally looking for a local sale, but can discussing shipping options for those interested. For reference, I live in Union County New Jersey. More pics available upon request.
Full tube roll and re-bias recently completed - JJ ECC83S for V1-V3, Sovtek 12AX7LPS for V4, matched pair of Mullard Reissue EL34s, and Mullard GZ34 for the rectifier spot.
Hand wired in Nashville, TN
Amp Specs:
Fender Blackface & Tweed + Marshall Plexi & Hot Rod channels in one amp. Can jump the American and British sides for a truly unique set of tones.
2 American channels - blackface + tweed circuits. Authentic blackface experience with an excellent balance of rich tone, punch and clarity. Flip the switch and you are in superb tweed growl.
On the British side of the pond, Early '68 "Super" Lead PLEXI Channel. The DREAM WEAVER MKII’s dual 12AX7 preamp and tone stack circuitry faithfully delivers an authentic plexi experience that leans toward an early ’68 plexi with its full-bodied frequency response, organic saturation and rich overtones. More signal gain can be added to the audio path via toggle switch to push your tone over the top.
Tube or Solid State Rectification
For the ultimate experience in the “feel” department, the Dream Weaver MKII gives you two rectifier options that are controlled via toggle switch. Choose between a tube rectifier (classic vintage power supply sag) or a solid-state rectifier (efficient, clear and punchy) and easily toggle between whichever you prefer.
HybridMASTER™ Volume Control and the Venue Switch give you the confidence to play what you feel when you feel it at exactly the volume you need for the occasion. Think of the Venue Switch as a “macro” volume adjustment – choose between full volume (Stage Mode) or an 70% volume reduction (Studio Mode) – and the HybridMASTER knob as a “micro” volume adjustment allowing you to fine tune your output levels.
Specifications
Model Name: Dream Weaver MKII
Power: Class AB, 35 Watts (tube rectified), ~40 Watts (solid state rectified)
Power Tubes: EL34 x 2
Preamp Tubes: V1 -V3: ECC83S, V4: 12AX7 LPS
Other Controls & Features: Presence, MASTER Control for Fine Tuning Output Level, FX Loop (tube-buffered pedal optimized series FX loop).
Weight: 29 lbs.
Case Composition: 5/8″ Birch
Speaker Outputs: 1 x 16, 2 x 8 and 2 x 4 Ohm Speaker Outputs
Dimensions: Head: 24″ x 10.5″ x 9.33″
Standby Switch Features: Middle Position: Standby Mode, Up Position: Rectifier 1, Down Position: Rectifier 2
Rectifiers: Tube and Solid-State power supply rectification selectable via the Standby Switch
Amp Specs:
Specifications
Weight: 29 lbs.
